Roman.e
Registrovaný: 25.7.2014
Auto: bmw e65
bmw e65 vypnutie protismyku
Piatok, 25. Júla 2014, 22:39
Zdravim chcem sa spytat ako sa da na bmw e65 vypnut protismyk dik za rady :)
msakac33
Re: bmw e65 vypnutie protismyku
Sobota, 26. Júla 2014, 08:45
cca 2 minuty hladania ](*,) ](*,) ](*,)
Activating DTC
You may find it useful to briefly activate
DTC under the following special circumstances:
> When rocking the vehicle and starting
off in deep snow or on loose road surfaces
> When ascending snow-covered hills,
and when driving in deep or on hardpacked
snow
> When driving with snow chains.
Select "Settings". Select "DTC" and confirm.
DTC is now activated. The DTC indicator
lamp in the Info Display lights up permanently.
When DTC is active, DSC provides
only limited system response up to a
speed of approx. 45 mph/70 km/h. Intervention
for stability enhancement is
reduced.<
Deactivating DTC again
DTC is now deactivated. The DTC
indicator lamp in the Info Display goes out.
DSC is once again available without
restriction.
Switching off DSC
Select "Settings". Select "DSC" and confirm.
DSC is deactivated. The indicator
lamp in the Info Display remains on continuously.
Deactivating DSC automatically deactivates
DTC as well. The systems for
enhancing stability and traction are deactivated,
and there is no active braking intervention
or torque control
You need to turn on Dynamic Traction Control (DTC). Go to Settings on the iDrive (lower left). The DTC icon is at the top. Highlight it and click on it so it turns green. Your car will now handle like a typical limited-slip differential rear wheel drive car. The DSC light on the dash will still come on if your wheels slip, but the computer can't control your car. If you have adaptive cruise control, it will not engage while DTC is on. DSC has to be able to control the car in order for ACC to work.
Roman.e
Auto: bmw e65
Sobota, 26. Júla 2014, 09:43
Dakujem pekne :) pomohli ste mi :)
