matisek
Registrovaný: 14.11.2012
Auto: F10, F48
E53 3.0d - Chybové kódy - INPA
Nedeľa, 1. Marca 2015, 19:00
Dnes som z Inpy vytiahol tieto chybové kódy - vie mi niekto povedat, čo znamenajú?
Jedná sa o 2005 (FL) E53 3.0d 160kW
SHADOW MEMORY REPORT
Date: 03/01/15 15:37:19
ECU: D_EGS
JobStatus: OKAY
Variant: GS19A
RESULT: 3 errors in error memory !
20358 Ratio-Monitoring Symptom Circuit-Monitoring
Warning: F_HFK doesn´t exist in result record 1 !
Warning: F_UW_ANZ doesn´t exist in result record 1 !
Warning: F_ART_ANZ doesn´t exist in result record 1 !
Errorcode: 4F 86 78
20760 InfoCounter1 - EGS-Reset
Warning: F_HFK doesn´t exist in result record 2 !
Warning: F_UW_ANZ doesn´t exist in result record 2 !
Warning: F_ART_ANZ doesn´t exist in result record 2 !
Errorcode: 51 18 78
20761 Reset at Bosch SW-Part
Warning: F_HFK doesn´t exist in result record 3 !
Warning: F_UW_ANZ doesn´t exist in result record 3 !
Warning: F_ART_ANZ doesn´t exist in result record 3 !
Errorcode: 51 19 22
ERROR MEMORY
Date: 01.03.2015 15:43:06
ECU: GS19A
JobStatus: OKAY
Variant: GS19A
RESULT: 1 error in error memory !
5140 Message from the DME/DDE is missing
P1720 CAN Timeout Control Module
Error counter: 1
Logistic counter: 40
Mileage 146904 km
time after reset/ignition OFF-ON 720.00 ms
Battery Voltage 9.52 Volt
Standard safeguard ACC (0=OK, 1=Error) 0.00 0/1
Standard safeguard CAS (0=OK, 1=Error) 0.00 0/1
Standard safeguard DME3 (0=OK, 1=Error) 0.00 0/1
Standard safeguard DME2 (0=OK, 1=Error) 0.00 0/1
Standard safeguard DME1 (0=OK, 1=Error) 0.00 0/1
Engine speed 0.00 rpm
Error CAN-Message
Test conditions fulfilled
Error not present now, but already stored
Error would not cause a warning lamp to light up
Error code: 51 40 28 17 20 00 00 01 28 47 BB 18 77 00 00 00
00 00 00 00 00 00 00 00 00 00 00
Ďakujem
Re: E53 3.0d - Chybové kódy - INPA
Pondelok, 2. Marca 2015, 07:40
prakticky nic vazne
pre nejaku chybu v zbernici sa pohadala riadiacka motora a riadiacka prevodovky (jedno aj druhe je zena, tak co si cakal?)
Pondelok, 2. Marca 2015, 07:57
tiez by som bol nasrany keby mi nedali jest :D
matisek
Auto: F10, F48
Pondelok, 2. Marca 2015, 10:30
Dik za odpovede.
Je pravda, ze auto som mal iba na nabijacke a asi preto tam to podpatie. Z toho dovodu asi aj ostatne RJ ani nenacitalo. Budem to musiet absolvovat pri nastartovanom motore a dam vediet.
Este nejaky hint - kde v Inpe zistim stav DPF filtra?
Pondelok, 2. Marca 2015, 12:09
Cez inpu to nezistis
matisek
Auto: F10, F48
Štvrtok, 19. Marca 2015, 21:14
Takze druhe kolo.
Toto som dnes vytiahol z inpy (kurvadrat preco to mam po nemecky?), 6x chyba zhavica (vo vypise iba jeden pre prehladnost).
Otazka je, ci su v riti zhavice alebo RJ zhavenia? V zime pri minusovych teplotach dost nachuja startuje, niekedy aj vobec, pritom bateria je relativne nova...
Tu som nasiel podobny problem, skusim pozriet este tie kable: BMW fault code: 4212, 4222, 4232, 4242
Este ma zaujima tento udaj: Error counter: 89
Znamena to, to co si myslim???
E R R O R M E M O R Y
---------------------------------------Date: 19.03.2015 17:00:22
ECU: D50M57B1
JobStatus: OKAY
Variant: D50M57B1
RESULT: 7 error in error memory !
4212 4212 Gluehkerze Zylinder 1
Error counter: 89
1. Umweltsatz
Mileage 146900 km
mittlere Motordrehzahl 717.14 rpm
Kühlmitteltemperatur 40.08 deg C
maximaler Raildruck der letzten 10ms 315.08 bar
Einspritzmenge Sollwert ohne Mengenausgleichsregelung 10.24 mg/cyc
angesaugte Luftmasse pro Zylinder 529.33 mg/Hub
Ladedruckwert 974.76 hPa
Linearisierter APP1 0.00 %
Batteriespannung 11893.62 mV
Fahrzeuggeschwindigkeit 0.00 km/h
Zustand der Glühanzeige 0.00 -2. Umweltsatz
Mileage 147070 km
mittlere Motordrehzahl 744.72 rpm
Kühlmitteltemperatur 52.13 deg C
maximaler Raildruck der letzten 10ms 307.21 bar
angesaugte Luftmasse pro Zylinder 497.83 mg/Hub
Ladedruckwert 984.61 hPa
Batteriespannung 11567.77 mV
Zustand der Glühanzeige 0.00 -Unterbrechung
Testbedingungen erfuellt
Fehler momentan nicht vorhanden, aber bereits gespeichert
Fehler wuerde kein Aufleuchten einer Warnlampe verursachen
Fehler in Entprellphase
Error code: 42 12 24 06 00 00 59 28 39 62 1A 5A 28 1A 54 63
00 49 00 00 39 73 1B 66 27 1A 4F 64 00 47 00 00
Piatok, 20. Marca 2015, 10:41
tipujem to na RJ
treba tie zhavice preskusat, pripadne to rovno vsetko vymen, nie je to az taka polozka a bude na par rokov pokoj
matisek
Auto: F10, F48
Piatok, 20. Marca 2015, 18:32
PeqpeK napísal:
tipujem to na RJ
Ved prave, rovno vymenit zhavice aj RJ.
Mechanik to chcel najskor merat, ci je to ozaj zle ale ked uz bude dole sanie a vsetko okolo toho, tak sa to rovno vymeni - nie je to az taka velka polozka (popripade decka budu menej zrat cez vikend :mrgreen: )
Ta chyba naskakuje po kazdom nastartovani a tusim uz ani PRE-HEATING neukazuje :-k
Piatok, 20. Marca 2015, 20:50
matisek napísal:
kazdemu to odporucam spravit pri jednej spine...a ak neboli menene tesnenia sania tak uz pre pokoj duse aj tie, predsalen je to uz starsie auto
matisek
Auto: F10, F48
Piatok, 20. Marca 2015, 22:53
PeqpeK napísal:
ok, tesnenie sania, pisem si :thumbup:
Piatok, 20. Marca 2015, 22:57
matisek napísal:
napis si aj zaslepenie klapiek, ak este nie su
matisek
Auto: F10, F48
Piatok, 20. Marca 2015, 23:01
PeqpeK napísal:
Nad tym tiez uvazujem. Netreba to aj niekde zapisat? Sa mi cosi zda, ze kdesi som cital, ze po zaslepeni zacalo niekde hadzat chybu...
Sobota, 21. Marca 2015, 09:52
matisek napísal:
Nie, len to treba dat inteligentnemu cloveku urobit :D
Nedeľa, 22. Marca 2015, 08:47
x5tky nemali zaslepky, aspon vsetky o ktorych viem
Nedeľa, 22. Marca 2015, 12:46
jararak napísal:
maju ich M57N s DPF
