MatkoBMW
Registrovaný: 19.11.2019
No communication possible with:....... X5 E70
Piatok, 5. Februára 2021, 09:19
Ahojte,
viete mi poradit s tymto?
Code Description Mileage Existent Class
S 0066 No communication possible with: Dynamic Drive -1 yes
S 0067 No communication possible with: Audio system controller -1 yes
S 0074 No communication possible with: Car Access System -1 yes
S 0096 No communication possible with: Air suspension -1 yes
S 0098 No communication possible with: Electronic fuel pump control module -1 yes
S 0099 No communication possible with: Parking brake -1 yes
S 0104 No communication possible with: High-beam assistant -1 yes
S 0105 No communication possible with: Roof function centre -1 yes
S 0108 No communication possible with: Luggage compartment lid module -1 yes
S 0116 No communication possible with: Headphone interface -1 yes
S 0117 No communication possible with: Heating and air conditioning system -1 yes
S 0159 No communication possible with: Comfort Access - 1 yes
S 0167 No communication possible with: Rear seat entertainment/multimedia
box
-1 yes
S 0180 No communication possible with: Safety module/restraint system -1 yes
S 0181 No communication possible with: Siren -1 yes
S 0204 No communication possible with: Transfer box -1 yes
S 0376 No communication possible with: MOST Gateway -1 yes
Auto funguje uplne normalne ... Diagnostika Delphi neukazuje ziadnu chybu so vsetkymi riadiackami sa normalne spoji. ISTA- D ukazuje toto... Moze to byt zle nainstalovanou diagnostikou ? Pripadne kde moze byt chyba? Baterka uz ma 7 rokov myslim ze uz ma to najlepsie za sebou...
Dik za rady...
Re: No communication possible with:....... X5 E70
Piatok, 5. Februára 2021, 09:57
To co citas, ake nezmysly... povovica ECU ti vobec neodpoveda... daj to pozriet niekomu na orig ISTA-D s ICOM, a nie na cinske kabliky
Piatok, 5. Februára 2021, 11:52
toto tu konkretne je zle nastaveny dcan kabel na 16ms namiesto 1ms, skus ako prve pozriet a potom to skus este raz nacitat. ak by to ozaj takto v reale nekomunikovalo - tak mas 2,5tonovu zelezoplastovu gulicku s ktorou nepohne ani boh
tesime sa na dalsie otazky co znamena ta alebo ona chyba
MatkoBMW
Piatok, 5. Februára 2021, 14:19
Bolo to spôsobené zle nainstalovanou diagnostikou.... po preinstalovani a opatovnom nastaveni kabla ide vsetko ako ma... Dik za rady...
Piatok, 5. Februára 2021, 18:02
jararak napísal:
