fioro
Registrovaný: 11.10.2007
Auto: 156 1,9JTD
Piatok, 14. Marca 2008, 17:36
BMW
5-Series
524td (1990-1991)
Engine Capacity 6 liter
Filter 1,75 liter
Use: Normal
MaxLife 10W-40
VR1 Racing Oil 5W-50
Differential, rear, limited slip Capacity 1,7 liter
Use: Normal
Special Product
Differential, rear Capacity 1,7 liter
Use: Normal
Special Product
Transmission, automatic Capacity 3 liter
Use: Normal
MaxLife ATF
ATF Type D
Transmission, manual Capacity 1,15 liter
Use: Normal
MaxLife ATF
ATF Type D
Hydraulic system, power steering/levelling
Use: Normal
Special Product
Hydraulic brakes/clutch system
Use: Normal
Service intervals:
Change 12 months
Brake & Clutch Fluid DOT 3/4
Power steering Capacity 1,2 liter
Use: Normal
MaxLife ATF
ATF Type D
Cooling system Capacity 12 liter
Use: Normal
Service intervals:
Change 24 months
Coolant Maxlife AF
Coolant AF Extreme
Coolant AF Extra
...... Obrázok......
BMW e34 525tds EX
Ford Transit 2,5 td EX
Opel Campo 2,5td 4x4 EX
Alfa 156 1,9 JTD
fioro
Auto: 156 1,9JTD
Piatok, 14. Marca 2008, 17:37
BMW e34 525tds EX
Alfa 156 1,9 JTD
xtreme
Registrovaný: 14.12.2006
Auto: felda, stilo
Piatok, 14. Marca 2008, 20:05
fiiihaaa... :shock: kks.. ma tu vzdy viete prekvapit.. diki moc..
xtreme
Auto: felda, stilo
Piatok, 21. Marca 2008, 21:25
inak co znamena na tom valvoline ... Capacity 6 liter
Filter 1,75 liter? pri engine oil..
fioro
Auto: 156 1,9JTD
Sobota, 22. Marca 2008, 07:33
no dokopy pri vymene filtra by malo ist spolu 7,75 litra ale to as mi zda vela :wink:
tu je nieco podobne od shellu , podla mna este lepsie ako ten valvoline...
http://shellus.rapidhost.co.uk/landing.asp?cid=2&selCountry=Czech+Republic&selLanguage=18
BMW e34 525tds EX
Alfa 156 1,9 JTD
modriblesk
Registrovaný: 7.4.2008
Auto: casto sa menia
naplne
Pondelok, 21. Apríla 2008, 20:37
"vav"
vidim ze sa tu ludia rozumeju. konecne som nasiel co som hladal.
tie stranky valvoline a shell su skvele pomocky, konecne viem ze mam vo svojej novej 524-ke motor e34.
a motor bude dostavat ako kazdy predosly diesel v mojich rukach: 10W-40.
a kedze olejova napln je dost velka ( cca 7 litrov ) tak afto velmi rychlo dostane bypass.
nech zije alpinweiss! HIP HIP HURAAAA !
kartmen
Registrovaný: 18.11.2010
Re: naplne ?
Štvrtok, 18. Novembra 2010, 13:27
spominali ste tu olej fuchs do niektorych BMW to ide ako prvonapln .. maju na stranke vecicku na tipovanie vhodneho oleja zadate si znacku motor model atd :)
http://www.olyslager-lubricants.nl/Fuch ... language=1
