MiroPT
Registrovaný: 20.10.2008
E91 320xd, N47 motor - chyby z INPY
Utorok, 29. Decembra 2015, 09:39
Ahojte,len tak namatkovo som si dal vycitat chyby cez INPU a vyhodilo mi ich dost :(.Pred nieco vyse mesiacom som nemal ani jednu. Problem je,ze ani na nene neviem k nim najst vysvetlenie, nasiel som len jednu,tu hned prvu. Ostatne nic. Nevedeli by ste mi s tym pomoct? Diky.
E R R O R M E M O R Y
Date: 26.12.2015 15:36:21
Model: E89X
Scope: all control module
JobStatus: OKAY
Quantity: 21
ADR Gen. name JobStatus Number of errors
Error code Kind of error
00 JBBF OKA Y No Error stored
01 MRS OKA Y No Error stored
12 DME/DDE OKA Y 1 Error stored
4873 21
4873: Exhaust gas recirculation cooling, plausibility
17 EKP OKA Y No Error stored
18 EGS OKA Y No Error stored
19 VGSG OKA Y No Error stored
29 DSC OKA Y 1 Error stored
5DEC A0
36 TEL/MULF OKA Y 2 Error stored
A8EF 20
A8F9 20
40 CAS OKA Y No Error stored
56 FZD OKA Y 2 Error stored
A670 21
DE88 20
60 KOMBI OKA Y No Error stored
61 FBI OKA Y 3 Error stored
AA05 A8
AA07 A8
AA08 28
62 MOSTGW OKA Y No Error stored
63 MASK/CCC OKA Y No Error stored
64 PDC OKA Y No Error stored
67 ZBE OKA Y No Error stored
72 FRM OKA Y No Error stored
73 CID OKA Y No Error stored
78 KLIMA OKA Y 1 Error stored
E723 24
92 VIRTSG92 OKA Y No Error stored
A0 CCC OKA Y No Error stored
k33p
Registrovaný: 15.4.2008
Auto: e87
Re: E91 320xd, N47 motor - chyby z INPY
Utorok, 29. Decembra 2015, 11:25
1. mas nejaky problem resp. pocit ze mas problem s autom?
2. ktore z tych chyb su trvale a ktore zas sporadicke, kolko krat a ako casto boli ulozene v pameti zavad?
pouzi normalnu diagnostiku DIS / ISTA / KTS
nieco tam pise s EGR, mozno termostat vadny a mozno nie, skratka, tymto zaznamom ktory si vlozil z inpy sa nedozvies nic viac.
z toho sa dozvies akurat tak ze nejake zavady tam su/boli ale co a preco a ci vobec to su zavady, ti nikto nepovie...
e87 118d
Ex.
e30 320i
e39 525d
e46 318i
e46 325i
e46 325i coupe
e90 330xd sedan
e46 320d sedan
MiroPT
Utorok, 29. Decembra 2015, 12:26
Min.tyzden som si namontoval stmievacie vnutorne zrkadlo. Skusil som odpojit konektor z neho a zbehol som check. Vsetko OK. Zrkadlo je aj s led pre dwa,zapojil som aj tu a to bola pricina vsetkeho. Odpojil som pin a nasledne mam vsetko ok,akurat tie chyby FZD ostali. Zrkadlo som normalne pridal ako VO,nakodoval aj v fzd,pekne funguje,pri zaradeni R sa odtmavi. Asi bude nejaka chyba v zrkadle.
k33p
Auto: e87
Utorok, 29. Decembra 2015, 12:32
nechapem co ma spolocne smievacie zrkadlo s DDE/DME alebo modulom klimi ci DSC, priatelu, veru tvoje fungujuce zrkadlo nieje pricina vsetkeho a vsetkych chyb v roznych moduloch :lol: :thumbup:
e87 118d
Ex.
e30 320i
e39 525d
e46 318i
e46 325i
e46 325i coupe
e90 330xd sedan
e46 320d sedan
MiroPT
Utorok, 29. Decembra 2015, 12:44
To nechapem ani ja. Ale neboli tam predtym a ked som ho odpojil nie su tam. A autu nic nie je
k33p
Auto: e87
Utorok, 29. Decembra 2015, 13:28
ok, este raz pre uplnost a naposledy.
- log z inpy co si sem dal nieje zmyslu plny, nic viac sa nedozvies
- inpa nieje diagnostika v pravom slova zmysle, pouzi na diagnostiku dis/ista/kts a daj udaje z nich
- tvoje spetne zrkadlo nesposobilo vsetky chyby v moduloch na aute, nanajvys 1 z nich ak vobec a to v module fzd nikde ide.
- ak ti funguje spetne zrkadlo tak ako ma a je teda aj spravne nakodovane, nieje co riesit s nim.
e87 118d
Ex.
e30 320i
e39 525d
e46 318i
e46 325i
e46 325i coupe
e90 330xd sedan
e46 320d sedan
MiroPT
Utorok, 29. Decembra 2015, 13:47
Problem vyrieseny. Fakt to vsetko zapricinilo pripojenie tej LED. A kedze ziadny alarm nemam,tak to ta Can zbernica nevedela rozchodit. Odpojil som ju,vymazal chyby z FZD modulu a vsetko je teraz OK. Dakujem za ochotu ;).
