Pondelok, 18. Februára 2008, 23:13
Engine: The engine in this e30 is a hand built 2.8L "stroker" engine. No expense spared, and the single highest specific output NA m20 I am aware of in the country. The engine is properly tuned with Unichip engine management, and with the HFM conversion and lightweight flywheel it really does feverishly rip to redline gear after gear. Idle is slightly lumpy, but is still quite steady and perfectly suitable for use on the street. I use high quality non-synthetic oils in it, and change it every 2500mi or less. I did try 5-w50 Castrol Syntec for about 4000mi but switched back because of excessive consumption, the design and gapping on the TotalSeal oil ring is not setup with such a thin oil in mind.
Exterior: The exterior really is everyone's favorite part isn't it? This is no exception. I could never really find a bodykit that I genuinely liked and felt looks appropriate so I picked and chose parts from newer BMW and reshaped/remolded them to fit my application. The end result is nothing short of stunning, and is definitely 100% unique. This car turns heads all day long, and believe it or not gets zero attention from the local police. It does not exude the "look at me" qualities that ricers do.. for example. I've had many enthusiasts chase after me hoping to get a couple questions in, or get me to pull over so they can have a good long look at the vehicle. Its really quite a treat to drive and be seen in. Everything tasteful you can really think to do has been done, and then some. The M-Doublespoke II wheels shown in the shoot with Misty below are not included with the car! They were replaced with the CSL replicas.
Suspension: Alot of extensive work has been done to the suspension. The car truly does handle like it is on rails. It will push well over 1.0 lateral G on a skid pad with the currently equipped wheels and tires. If one was to add some nice R comps for track usage this car could be a devastatingly effective tool. The heart of the suspension would be the Ground Control coilovers and the Koni SA dampeners. While very firm they still ride surprisingly well. Highway cruising isn't brutal, and around town is more then livable. Some have no doubt noted the conversion to 5lug, and the accompanying big brakes front and rear. MZ3 trailing arms were used in the rear for the enforcements and massive brakes. e30 M3 front strut housings used in front for proper geometry. None of that halfass caster challenged e36 M3 strut housing crap here. Wheels are 18x8.5 e46 M3 CSL replicas made by Velocity Motoring. Tires are 245/35R18 Toyo T1R all around. Tires have 90% or better tread. No track days, burnouts, "drifting" or other assorted abuse on these tires. Coilovers are currently set as low as they go in the rear, and about 1/2in up from as low as possible in the front. Rear wheels/tires do not rub on the fenders under any circumstances, front tires will rub on the fender lip (rolled so it will NOT catch) under extreme cornering. Because of the sheer size of the front wheels and tires they do rub the inner wheel well rails at full lock. A small amount of your turning circle is sacrificed in the name of handling. Parking etc is not an issue.
Brakes: The brakes have got to be one of my most favorite parts of the car. Its really hard to decide, but they are definitely up there. The front and rear rotors are identical to stock e36 M3 units (same part numbers and all) Front calipers are e36 M3, and rear calipers are slightly different then e36 M3, but feature the same piston diameter and pad surface area. Anyone who has every had the opportunity to drive a e36 M3 up to speed and stand on the brake pedal knows how monstrously fast those brakes bring the car back to sane speeds. Now imagine the same brakes, attached to 500+lbs less car. Plain and simple these are variable anchors. I've never been able to make them fade, and they will engage the fully functional ABS if you stand on it well over 130mph. Pads are currently OE Jurid rear, and OE Pagid front. Saw no need for more aggressive pads, but that is certainly an option. All 4 calipers were completely disassembled, degreased, bead blasted, washed, honed, and resealed/rebuilt with new seals, guides, etc.
Drivetrain and Exhaust: The drivetrain is mostly stock, there is not a whole lot to improve upon here in any application I every planned for the car. I have fitted a 4.10:1 LSD, lightweight flywheel, 6 puck unsprung metallic clutch, and beefy MZ3 halfshafts. The shifter linkage has been modified to keep it very tight by using brass bushings instead of rubber and plastic. The exhaust is highly modified. Fully Jethot coated headers and catless midpipes. Custom bent pipes into a dual in/out straight through Brullen muffler that is more of a resonator at this point. This exhaust does NOT exhibit any of the rasp characteristic of ricers. It is VERY open and free flowing, and is loud, but not so loud as to constantly attract attention from law enforcement. I have never been pulled over, ticketed, etc for the exhaust. I don't expect you will either unless you rip past a cop at WOT.[list=][/list]
- 033006-001.jpg (413.79 KiB) 793117 zobrazení
- 033006-003.jpg (397.72 KiB) 793111 zobrazení
- 041506-006.jpg (336.96 KiB) 793107 zobrazení
- 041506-007.jpg (248.01 KiB) 793105 zobrazení
- 041506-010.jpg (268.8 KiB) 793113 zobrazení
- 042306-005.jpg (276.11 KiB) 793126 zobrazení
- 042306-012.jpg (270.68 KiB) 793130 zobrazení
- 042306-014.jpg (282.06 KiB) 793142 zobrazení
- 050606-003.jpg (245.87 KiB) 793149 zobrazení
- 050606-006.jpg (324.83 KiB) 793160 zobrazení
- 050606-007.jpg (214.32 KiB) 793164 zobrazení
- 091805-005.jpg (307.05 KiB) 793185 zobrazení
- 091805-006.jpg (406.86 KiB) 793197 zobrazení
- 091805-007.jpg (333 KiB) 793225 zobrazení
- 102205-010.JPG (360.5 KiB) 793237 zobrazení
- 102205-011.JPG (423.99 KiB) 793256 zobrazení
- 102205-012.JPG (360.34 KiB) 793265 zobrazení
- 110505-002.jpg (229.29 KiB) 793299 zobrazení
- 120405-002.jpg (386.52 KiB) 793258 zobrazení
BMW G05 40i
BMW G01 M40i
BMW F15 40d EX
Ford mondeo mk4
BMW E91 318d EX
BMW F07 530d EX
BMW E61 530DT A/T EX
BMW e53 4,8is EX
BMW e53 4,6is EX
BMW e36 323i coupe EX
BMW e30 325i coupe EX
BMW e34 520iA sedan EX
BMW e46 323i sedan EX
