Lukynko
Registrovaný: 28.11.2010
Auto: E34 2.5TDs-ko :)
Co to je?
Pondelok, 7. Januára 2013, 21:34
Zdravicko...
Nasiel som toto v aute - co to vlastne?
Nasiel som to v skrinke riadiacich jednotiek podla mna to bola riadiaca jednotka niecoho, alebo cesntralna riadiacia jednotka? Ale pise tam chip cize moze to byt chipovane moje auto? Aj ked nevyzera...
Poprosim o definiciu: Na co to sluzi, Co to robi, Co to je?
chip 2.jpg (56.85 KiB) 2403 zobrazení
Re: Co to je?
Pondelok, 7. Januára 2013, 21:43
ked na tom pise chip, bude to chip (powerbox), kam vedie kabel? ide skrz to alebo len do toho? ak len do toho, odkial?
co tak pouzit cas od casu internet?
http://www.d-chip-tuning.de/free/produk ... _basic.htm
tu to je prelozene len google translatorom ale vcelku do pohody
An intelligent power is on call when you need it. D chip basic works on this principle. Need more power, e.g. when driving on hills or when towing a trailer load of high load, it switches to the D chip.
The operation of the D chip and basic Airtronic based on the MSP technology (Mixed-Signal Processing). Similar to our additional computers, connection is a function of load, also the engine is operating in the absence of the necessary performance data always in series, programmed by the manufacturer runflat tires in the main control remain even after the installation of the D-chip fully preserved. The more services are moving depending on the vehicle and factory output between 20 and 25%.
Naposledy upravil/-a jararak v Pondelok, 7. Januára 2013, 21:47, upravené celkom 1 krát.
fioro
Registrovaný: 11.10.2007
Auto: 156 1,9JTD
Re: Co to je?
Pondelok, 7. Januára 2013, 21:46
no sak keby si dal gugel tak to mas jasne hned http://www.d-chip-tuning.de/free/produk ... _basic.htm mozno to mas odpojene
...... Obrázok......
BMW e34 525tds EX
Ford Transit 2,5 td EX
Opel Campo 2,5td 4x4 EX
Alfa 156 1,9 JTD
Lukynko
Re: Co to je?
Pondelok, 7. Januára 2013, 21:49
Inteligentné napájanie je na volanie, keď ju budete potrebovať. D čip základné práce na tomto princípe. Potrebujete viac energie, napr pri jazde na kopcoch alebo pri ťahaní prívesu vysoké zaťaženie, prepne sa do D čipu.
Prevádzka D čipu a základné AIRTRONIC založeného na technológii MSP (Mixed-Signal Processing). Podobne ako naše ďalšie počítače, pripojenie je funkcia zaťaženie, aj motor pracuje v chýbajúcom nevyhnutným výkonnostných dát vždy v sérii, programované pneumatikami výrobcu RunFlat v hlavnom konaní zostávajú aj po inštalácii D-čipu plne zachovaná. Čím viac služieb sa pohybujú v závislosti na vozidle a továrenské výstupom medzi 20 a 25%.
A VYSOMAR SA S TOHO
Hammern4s
Registrovaný: 9.12.2012
Re: Co to je?
Utorok, 8. Januára 2013, 00:59
Asi takto:
Inteligentná sila je pripravena na pouzitie v pripade potreby. D-chip Basic funguje na nasledovnom principe, v pripade, že potrebujete dodatocny výkon, napr. pri jazde do kopca, ťahaní alebo pri plnom naložení, zapojí sa D-Chip. Funkcia D-Chipu Basic a Airtronic je založená na principe technológie MSP ( mixed-signal procesing) a podobne ako u nasich ďaľších prídavných jednotiek je ich spustenie zavislé od zaťaže. V pripade normalnej záťaže pracuje motor v sériovom nastavení, ktore bolo nahrané vyrobcom do riadiacej jednotky a zostáva nezmenené aj po inštalácii D-Chipu. Zvyšenie vykonu je v závislosti od vozidla a sérioveho výkonu v rozsahu 20-25 %.
Rychly a hruby preklad :D
Lukynko
Re: Co to je?
Utorok, 8. Januára 2013, 09:56
si super..dakujem vsetkym za info :)
Užívatelia prezerajúci toto fórum: Google [Bot] a 22 neregistrovaných
