catchcash
Registrovaný: 15.8.2024
Auto: X3 xDrive30d
vypinanie xDrive
Štvrtok, 5. Júna 2025, 09:00
Ahojte,
Ak sa to tu uz riesilo sa ospravedlnujem (skusal som hladat ale nenasiel som). Predajca mi povedal, ze xdrive vypina predok pri vyssej rychlosti na dialnici. Neviete nahodou ci je to naozaj pravda a ak ano aka je ta rychlost? Pytam sa to cisto zo zvedavosti nemam ziadny problem ani nic podobne :)
Dakujem
catchcash
Auto: X3 xDrive30d
Re: vypinanie xDrive
Štvrtok, 5. Júna 2025, 09:04
AI tvrdi toto:
BMW's xDrive system, an all-wheel drive (AWD) system, does not have a specific speed at which it switches off the front wheel drive (FWD). It's a continuously variable, full-time AWD system that continuously monitors and adjusts power distribution between the front and rear wheels based on driving conditions, according to various sources
In most normal driving situations, xDrive typically distributes power with a 40/60 split (front/rear), according to BMW's technology guide.
However, it can dynamically adjust this split, even sending all power to one axle if needed, depending on factors like road surface, traction, and driving style. Therefore, there isn't a specific speed where FWD is "turned off," but rather a continuous adjustment of power distribution based on real-time conditions.
For example, at high speeds or when parking, the clutch might be disengaged, and all power goes to the rear wheels. However, this is a dynamic adjustment, not a hard cutoff of FWD at a specific speed.
Cize sa asi neda jednoznacne povedat, kedy to vypina...je to tak salamunsky vyriesene :D
