BioPL
Registrovaný: 7.2.2015
Auto: G21
Code 2BBA00
Nedeľa, 20. Októbra 2024, 16:02
Pacient: 3er G21 318d 2021.
Môže mi niekto pomôcť identifikovať, kde to je a ktorý "particle sensor" kúpiť na kód: 2BBA00?
Myslím, že je to len jeden z týchto "show check engine sensors" - pretože keď som skontroloval opravy motora a ostatné veci - nič sa nezmenilo. Rovnako ako druha, lambda za katalyzátorom v starších autách.
Nemôžem s istotou identifikovať nič rozumné cez realoem (a realoem končí v roku 2019), ale blízka zhoda je číslo 13, časť: 13628582026
https://www.realoem.com/bmw/enUS/showpa ... 9KUPUy4IyQ
Mohol by niekto potvrdiť?
3er G21 318d MHEV
MX-5 NC1 2.0 Soft-Top
Re: Code 2BBA00
Pondelok, 21. Októbra 2024, 08:45
Should be the 13. but to make sure, I'd disconnect one of them and see the codes. What is the text associated with the fault code? I can help you with getting the exact part no. if you provide a VIN code
BioPL
Auto: G21
Re: Code 2BBA00
Utorok, 22. Októbra 2024, 09:22
O - even in english :D
VIN: WBA6L31020FL51455
I went YOLO and just ordered BOSCH 0 281 008 466, so we will see. Replacement should be easy (not like someone ever died under a car...) then I'll see if error will come back after 300+km (usually it comes back after erasing it via BimmerLink)
3er G21 318d MHEV
Re: Code 2BBA00
Streda, 23. Októbra 2024, 21:24
Here the correct P/N for your vehicle, as well as current version of i-level
BioPL
Auto: G21
Re: Code 2BBA00
Štvrtok, 24. Októbra 2024, 12:51
Thanks for this. Looks like BMW in meantime updated sensor (or at least P/N so you cannot order it from normal parts store, thanks BMW for respecting "right to repair")
Changed sensor to: 13628582026, so Bosch: 0 281 008 466. And it's the same Bosch number that I had mounted, so I should be fine... for another 150+kkm at least :D
After erasing error, (2bba00 - diesel particulate sensor temperature signal not plausible), starting car 3 times, nothing came up so sensor should be fine (if it would be totally wrong then it would throw error from cold engine even) but will see in couple of days. I have on Saturday a longer trip, so will see if error will be triggered again.
BTW: What is I level? Edit: a ok - got it.
I did updated software via MyBMW, so I have 11/2023.50 firmware now - whatever that does.
Edit 2: and looks like Bosch 0 281 008 466 solved issue - 800km done, 10+ starts, no error.
3er G21 318d MHEV
dab
Registrovaný: 27.3.2025
Auto: g31 LCI
Re: Code 2BBA00
Streda, 23. Apríla 2025, 11:08
Hello
I have a similar problem, I think...
2BBA00 - Diesel particulate sensor, temperature signal: Not plausible.
I have this error returned after reset for a half year without check engine.
Now i have check engine and after reset it appear after 100 km.
My car:
G31 LCI xDrive B47 2021 with 115 kkm mileage.
VIN: WBA51BN030CG98626
Can you help me do find which sensor should be replaced?
It will be the same as above in replies?
Best Regards,
Damian,
Central Poland
Re: Code 2BBA00
Streda, 23. Apríla 2025, 19:31
it's the same error code, same sensor
dab
Auto: g31 LCI
Re: Code 2BBA00
Piatok, 25. Apríla 2025, 09:06
Thank you.
