barabas
Registrovaný: 29.5.2007
ako oklamat ochranu pri dvojvrstovych navi. dvd(2008.1/2)
Piatok, 19. Decembra 2008, 09:04
napisal som to povodne v englisch dakto to prelozte pls:)
v podstate ide o to vtrepat data z dvojvrstvoveho dvd na jedno vrstvove, ako? vhodit prebytocny balast(jazyky ktore nepotrebujeme)
hi,
many of you had the same problem, if we wanted to use the latest navigation dual layer dvd of europe, we had to buy it, because in many cars the dvd could not be read...
so i analyzed the file structure of the dvd, i saw that the idrive is running on a linux/unix system(ELF binaries) and it has an own web server and uses htm files for generating of the user interface
so ive tried to shrink the dl dvd image to a single layer dvd.
what do you have to do, to bypass the security check:
1. save your dvd image to an iso file
2. edit this file with for example UltraISO or a different iso editor
3. delete all directories inside the directory: tpd\ntcBeuFNM_eu_20080401\ except of ENG or the language that you want to use
4. edit the file: tpd\ntcBeuFNM_eu_20080401\INFO15.PSC
5. remove all the information about removed languages (see attached file)
6. save and burn the dvd image
7. enjoy it
INFO15.zip
(1.02 KiB) 267 stiahnutí
Piatok, 19. Decembra 2008, 10:31
No nazdar
vela z Nas ma podobny problem, ked chceme pouzit najnovsie dvojvrstvove dvd s navigaciou europy, musime si ho zakupit, pretoze vo vecsine aut dvd nevie precitat vypalene dvd
tak som zanalyzoval subory na dvd, prisiel som nato ze idrive bezi na linux/unix systeme (ELF binarky) a ma vlastny web server, cize vyuziva htm subory na generovanie uzivatelskeho prostriedia
tak som sa pokusil zmensit dvojvrstvovy dvd immage na jednovrstvovy
takze co musite urobit nato aby ste obysli bezpecnostnu kontrolu:
1. ulozte svoj dvd obraz ako iso subor
2. upravte tento subor (napriklad s UltraISO alebo s inym iso editorom)
3. zmazte vsetky adresare v nasledujucom adresary
tpd/ntcBeuFNM_eu_20080401/ az na ENG alebo jazyk ktory pozadujete
4. upravte subor: tpd/ntcBeuFNM_eu_20080401/INFO15.PSC
5. vymazte vsetky informacie o jazykoch ktore ste vymazali (pozrite prilozeny subor)
6. ulozte a vypalte dvd obraz
7. uzite si to :)
kludne ma opravte ak som sa v niecom pomylil alebo mate lepsi preklad
stjr
Registrovaný: 1.8.2006
Auto: Otec ma Feliciu
Re: ako oklamat ochranu pri dvojvrstovych navi. dvd(2008.1/2
Piatok, 19. Decembra 2008, 11:32
barabas napísal:
hi,
7. enjoy it
Nie je to potrebne. Najnovsie navigacne DVD (na rok 2009) uz je opat jednovrstvove a pritom je rozsirene o dost vela krajin oproti tomu co spominas ty. Je tam napriklad HR, PL co v minulosti chybalo.
Dokonca mi s nim po prvy krat zacalo fungovat TMC takze maximalna spokojnost.
Inak, ani to 2-vrstove nebol problem. Treba ho akurat vypalit nizkou rychlostou a slape to. Jediny problem co som postrehol bol, ze tym ze je dvojvrstove je zrejme viac nachylne na otrasy a dost casto sa mi stavalo, ze to mechanika nevedela precitat a dostal som 'error' hlasku. Stacilo potom vybrat DVD a spatne ho vlozit dnu a rozbehlo sa to.
Peppo
Registrovaný: 7.3.2007
Auto: TOYOTA PRIUS
Piatok, 19. Decembra 2008, 11:47
stjr napísal:
mas to 2009:??? professional? zaloha pre peppika???
TMC fungovalo aj s 01/2008 v pohode v rakusku....
je tam aj HU??
stjr
Piatok, 19. Decembra 2008, 11:50
Peppo napísal:
je tam aj HU??
Samozrejme ze to mam, uz 2 tyzdne sa mi to kruti v aute. JJ, professional...
Mne TMC v Prahe nefungovalo pred tym a inde som s autom nebol tak neviem, ale teraz sa to rozbehlo s tou novou verziou a viem na 100% ze TMC v Prahe funguje uz aspon rok.
Zajtra prechadzam cez BA takze som otvoreny navrhom ako/kde si to chces prevziat... ;-)
Piatok, 19. Decembra 2008, 11:59
Ja uz tiez tocim 2009.
TMC mi fungovalo odjakziva aj s verziou 2005. Aj v rakusku.
Peppo
Auto: TOYOTA PRIUS
Piatok, 19. Decembra 2008, 12:39
mne to chyta rakuske dopravne spravy aj v Trnave... tj daleko od BA... hehe...
stjr - SS
stjr
Piatok, 19. Decembra 2008, 13:52
Peppo napísal:
stjr - SS
Aha, no niekde som cital ze navigacny soft/mapa musi mat nejake specialne 'tabulky' pre TMC a inak to nefunguje aj ked je ten RDS-TMC signal prijimany...
Na Slovensku to este nefunguje?
Inak videl si Peppo novy iDrive v E92? Naaaaadhera. Tie mapy (vizual) a cely interface je neskutocne premakany. Moj je v porovnani s tym novym jak elektronicka hra zo Sovietskeho zvazu...
Naposledy upravil/-a stjr v Piatok, 19. Decembra 2008, 14:03, upravené celkom 1 krát.
markom
Registrovaný: 27.9.2008
Nemate niekto aj 2009 business?
Piatok, 19. Decembra 2008, 13:54
Peppo
Auto: TOYOTA PRIUS
Piatok, 19. Decembra 2008, 15:42
stjr napísal:
novy iDrive ako hardwarovo novy alebo len novy vzhlad?
stjr
Piatok, 19. Decembra 2008, 17:17
Peppo napísal:
Uplne novy, ovladanie aj vzhlad.
Mrkni: http://www.e90post.com/forums/showthread.php?t=179330
barabas
Piatok, 19. Decembra 2008, 17:44
peppo, jasne napalime...
2009.1 je uz pre europu? ja som ztial postrehol len pre usa...
tmc na sr smola, akurat tak ciastocne cechy a rakusko frci...
TiTAN
Administrátor
Auto: BMW 530d xDrive
Sobota, 20. Decembra 2008, 10:03
barabas napísal:
no u nas kym spustia TMC :twisted: :twisted: ked to bude ako s DVB-T :twisted:
barabas
Sobota, 20. Decembra 2008, 10:19
a predsa uz su 2009.1 eu mapy, dal som tahat, uvidime ako...
pablo_s
Registrovaný: 23.2.2007
Auto: G21 320xd
Nedeľa, 21. Decembra 2008, 21:12
pri novych multilanguage mapach je editacia na jenovrstve DVD identicka ako pri starsich verziach (napr tie 2008-2) iba adresar kde su mapy ma trochu iny nazov a ten psc cubor ma trochu iny nazov ale podobnu strukturu, len to treba editovat v niecom inom ako notepade alebo wordpade!!!, lebo je to z linuxu a editaciu je treba urobit v programe typu VEdit, potom to bude mat po vyhodeni jazykov cca 4 GB a v pohode to vlezie na jednovrstve DVD.
Užívatelia prezerajúci toto fórum: Žiadny pripojení užívatelia a 50 neregistrovaných
