Rodys
Registrovaný: 31.7.2013
Auto: BMW E46
Aktualna spotreba E83(x3)
Nedeľa, 3. Mája 2015, 07:23
Caute, neukazuje x3 mod. 2007 aktualnu spotrebu vobec? Alebo sa to da nejako nastavit?
Re: Aktualna spotreba E83(x3)
Nedeľa, 3. Mája 2015, 12:38
A skusil si hladat pod otackomerom?
Rodys
Auto: BMW E46
Nedeľa, 3. Mája 2015, 14:00
Tam je tak ukazovatel nadrze a teploty.. Alebo som slepy?
Pondelok, 4. Mája 2015, 06:03
fuu, v tom pripade sorrac, taketo usporiadanie pristrojovky som snad este nevidel (v x3 som sedel snad 2x), vsetky bmw ktore si pametam maju takto rozlozene, dokonca aj tie, co to maju digital
co som hladal na nete, vraj to nejde, jedine ak si odomknes menu, navod v anglictine, ak chces, prelozim
Instructions to access the hidden OBC functions:
1. Hold down Trip Reset button while inserting ignition key / Press and Hold down Trip Reset button >10 seconds when idle.
2. Right after – if you wait 2 seconds – menu 01.00 appears, where you can check your cars VIN number (you will need it to unlock all hidden functions). At this point only menues 01 and 02 are unlocked, others are still locked.
3. You can also skip waiting in step 2 (in case you already know VIN and you wish to proceed) and immediately use Trip Reset button to select function 19.00, where you can unlock all the other features. Indicator first shows LOCK ON.
4. Wait for display to show "CODE 00", then enter the sum of last 5 digits from your cars VIN number with Trip Reset button.
5. Other hidden functions are now unlocked and display starts with function 01.00.
6. To move between sub-menus press Trip Reset.
7. To change menus first depress Trip Reset for 2 seconds to appear »_ _«, then several times to select desired function.
8. Secret menu remains unlocked until you turn ignition off.
tu je k tomu aj videjko, sice e46, ale ono to je zhodne
Rodys
Auto: BMW E46
Pondelok, 4. Mája 2015, 09:43
Vdaka za ochotu, tiez som zvyknuty na take rozlozenie ako si pridaval obrazok. Ak by si mal cas mohol by si to prelozit. Este raz vdaka :)
Pondelok, 4. Mája 2015, 11:56
V skratke
1, zrataj si svoje vin - poslednych 5 znakov - ja mam gs68102 6+8+1+0+2=17 - to je kod na odomknutie
2, drz nulovacie tlacidlo prejdenej vzdialenosti a otoc klucom=zapni zapalovanie
3, skod na bod 19 kde by to od teba malo vyzadovat CODE 00 - vytukaj tam tvoj kod (moj bol 17)
4, hura, mal by si to mat odomknute, ak pise LOCK ON, nieco neprebehlo ako malo, opakuj
5, medzi hlavnymi menu sa prepinas dlhymi stlaceniami (asi 2sek) medzi podmenu len kratkym stlacenim
6, menu sa vytrati, akonahle vypnes zapalovanie
* nenesiem ziadnu zodpovednost za chyby v preklade ak to nieco poskodi, vsetko obsiahnute v tomto navode robite na vlastne rizoto
** nemam jednopackovy stroj aby som to mohol oskusat, ja mam packy 2 cize to mam troska inteligentnejsie
Sobota, 23. Mája 2015, 17:26
Ja som este nevidel x3 e83, ktora by ukazovala spotrebu
Adame
Registrovaný: 20.3.2016
Auto: BMW X3 2.0D
Štvrtok, 30. Apríla 2020, 09:14
Ahojte kedze je tu okno o X3 a spotreba tak to tu hodim ... mam podozrenie na vysoku spotrebu jedna sa o X3 pred fl. 2.0/110d no spotrebu mam na budikoch okolo 10 az 11 ... jazdim mesto a okresky a snazim sa tak v rozmedzi 2-3tis ot. Ked som siel po dialnici tak 8.8l .kolesa 235 r17 ... myslite ze je to relativne ok? Ide o motor M s dpf
Pondelok, 11. Mája 2020, 16:04
je to trochu viac ako by malo byt podla mna.... ak je to manual.... zrejme ho moc dusis..... spotreba nezavisi od otacok..... ale od toho, kolko mnozstva sa vstrekuje do motora a ako je zatazeny.
x-drive s nulovou dynamikou nikdy nebude jazdit za 5.5 litrov. Na dialnici pri rychlostiach nad 120-130kmh zacne spotreba rast rychlo.... jazda po meste je velmi subjektivna zalezitost.... neda sa povedat ktore vozidlo ma kolko zrat v meste. lebo je rozdiel sa vozit po meste vecer po obchvate a cez den, kde sa auto niekedy pohybuje krokmi po piatich metroch v zapchach. Vtedy moze byt spotreba akakolvek.... Ale velmi zaujimavy udaj ako to porovnat, je priemerna rychlost. Lebo vozidlo co jazdi v meste a ma priemernu rychlost na tankovanie 45kmh zozerie ovela menej ako to iste auto ktore spravi priemernu rychlost 30kmh.....
Skus zmerat realnu spotrebu na vyjazdenie jednej nadrze podla tankovania presne a porovnaj s tym co udava BC. Ak je ten udaj nepresny, da sa spravit korekcia. Pokial je motor v poriadku a nic vazne ho netrapi, tak nema preco zrat viac ako ostatne rovnake vozidla.
