DanySVK112
Registrovaný: 6.6.2021
Auto: BMW X5 E70
E70 Webasto parovanie dialkoveho
Pondelok, 7. Júna 2021, 05:57
Ahojte
Mám originál od výroby v svojom BMW E70 webasto, ktoré funguje bez problémov okrem diaľkového. Čo som tu hľadal, tak som sa dočítal, že to treba spárovať nejako cez poistku ale nikto už nespomína môj model a ani ktorá poistka v tomto modeli BMW (e70) to je. Vedel by mi stým niekto pomôcť aké označenie a kde sa nachádza tá poistka?
Re: E70 Webasto parovanie dialkoveho
Pondelok, 7. Júna 2021, 06:57
Coding BMW parking heater remote instructions:
To initialize a new hand transmitter, perform the following
operations from inside the vehicle:
•Close all doors on vehicle (vehicle must be unlocked!)
•Within 5 seconds: Turn ignition lock from terminal "0" toterminal "R" and then back to terminal "0" (by inserting and
removing key, insertion duration: 1 to 5 secs.)
•Within 5 seconds: Simultaneously press both buttons (1, 2)on hand transmitter until LED (3) lights up orange.
•Release both buttons. Briefly press ON button (1) threetimes within 10 seconds; LED (3) flashes orange as
confirmation.
Note:The vehicle's central locking closes and opens automatically on
successfulinitialization.Theinitialization process must be repeated if there is no
checkback signal from the central locking system.
DanySVK112
Auto: BMW X5 E70
Utorok, 8. Júna 2021, 05:47
Ďakujem... :D skusim
DanySVK112
Auto: BMW X5 E70
Streda, 9. Júna 2021, 08:49
starynovy napísal:
confirmation.
Funguje :D :D Ďakujem
